علي مرشد
Dec 3
It used to be recommended to use 95 octane fuel, and it was labeled as such. Why has it changed to 92 now?
Comments( 6 )
Can a 2018 F150 use 92 octane fuel?
Can the 720s use 92 octane fuel?
Can the 2019 4WD model use 92 octane fuel?
4Do I need to fill the P1 with 92 or 95 octane fuel?
5Does the 2011 MDX use 92 or 95 octane fuel?
6Can using 95-octane fuel provide a power boost for a vehicle like the Kia Sportage that specifies 93-octane (now equivalent to 92-octane)?
7In 2022, the car required 95 octane fuel, but for the 2024 model, it uses 92 octane fuel. I checked and it seems like nothing has changed. Why is that?
8I've been using 95 octane fuel for two and a half years. Should I continue with 95 or switch to 92? Thanks.
9The new Jetta VS7 now specifies the use of 92-octane gasoline, while the 2021 version specified 95-octane. I've always used 95-octane gasoline. Has the new engine been technically improved compared to the old one?
10Are you using 95 or 98 octane fuel?
