Guys, how do you fix the resonance issue in the 2023 Nissan X-Trail Glory between 1700 to 2000 RPM?
Touareg 3.0, after over 20,000 km, experiencing differential resonance when turning. The dealer isn't resolving it, saying it's a design flaw. The differential is smaller than before. Changing the differential oil can temporarily fix it, but the resonance returns after another 20,000-30,000 km. Do you guys have this resonance issue with your cars?
What do you think about the three-cylinder Nissan X-Trail? Please share your thoughts.
What is the fuel consumption of the Nissan X-Trail e-Power for the first time?
4Which one is better, the Nissan X-Trail e-Power or the Mazda CX-50?
5Does the Nissan X-Trail Classic have a leakage issue? Should I cut off the sunroof drain hole insect screen in advance? Should I use underbody armor spray?
6Is it normal for the brake pedal of the Nissan X-Trail Classic to make a loud noise when it rebounds and contacts the brake light switch?
7Is the 2023 Nissan X-Trail equipped with a three-cylinder or four-cylinder engine?
8Can owners of the 2021 Nissan X-Trail play video songs while driving?
9The 2020 Nissan X-Trail sometimes has a start-stop malfunction when starting the car. What could be the reason for this?!!!
10Is it common for a 2016 Nissan X-Trail with 120,000 km to have the air conditioning leaking refrigerant after two long trips, with a two-month interval? Is it an issue with the compressor or the evaporator leaking?
