Is it the same for everyone with the 2024 Villa Pro that there's no seatbelt reminder for the passenger seat? There's also no reminder for the driver's seat, it just doesn't move when you press the gas, and you have to manually release the handbrake.
Why does the seatbelt alarm keep going off even though there's no one sitting in my passenger seat? Can anyone help me figure this out?
What could cause the driver's seat to move forward but not backward?
Hi everyone, for the 2019 Hongqi H7, is it possible to move the gear lever button from the passenger side to the driver side?
4Is the hood of the Grand Cherokee lower on the right side? When sitting in the driver's seat and the passenger seat, the hood seems to have different heights. From the passenger seat, the right side of the hood appears to have a greater curve, but from the driver's seat, the left side doesn't seem to have as much curve as the right. The car is parked on level ground, and the seats are adjusted the same, but the issue persists. However, when viewed from outside the car, there seems to be no problem. Is this a visual perception issue?
5Is the ambient lighting in the 2024 Villa Pro only in the front row or in both the front and rear rows? Mine only has it in the front row.
6How do you turn off the rear seatbelt reminder on this car?
7Does the driver's seat have a memory function, and how do you operate it?
8When you enter the GV80 and the driver's seat adjusts automatically, does the buzzing sound continue for a while after it stops moving? Has anyone else experienced this? Thanks.
9Do you have issues with the driver's seat collapsing in your car?
10The driver's seatbelt height can't be adjusted. Do any of you have this issue?
