عمر عماد
عمر عماد
Oct 28
ZS 2017 model has a lot of driving noise. It doesn't seem like engine noise; it's more of a humming sound. Does anyone with the same model experience this?
Comments( 7 )
نايف نوري
نايف نوري2024-04-19 09:56
My car was making a "da-da-da" sound, and after checking, it turned out to be a damaged bearing inside the transmission. It cost me 7000 yuan, damn!
عبد العزيز أنور
عبد العزيز أنور2024-04-17 17:16
I also have the 2017 model. If there's a strange noise at a fixed RPM, it might be due to a dirty throttle. My car makes a buzzing noise around 60 km/h, but not below or above that speed. After cleaning the throttle, the issue disappeared.
عبدالله وسيم
عبدالله وسيم2024-02-29 08:32
How did you solve it?
20
حسين يعقوبي
حسين يعقوبي2019-10-28 20:46
Regarding the buzzing sound you mentioned while driving, it could be due to tire noise or possibly the sound coming from the chassis or bearings.
محمد بشير
محمد بشير2019-10-28 20:31
There are two possibilities for this buzzing sound. One is tire noise; if the tires are unevenly worn or deformed, this kind of sound can occur. The second is damage to the bearings, which can also cause this.
حسن سعد
حسن سعد2019-10-28 20:28
The engine noise of this car is indeed a bit loud. If you have high expectations for the cabin's quietness, you might consider doing a full car soundproofing. Although it's a bit pricey, the results are really impressive.
عبدالله عيسى
عبدالله عيسى2019-10-28 20:27
If there's a humming noise while driving that gets louder with speed, it's likely an issue with the wheel bearings. If the noise remains constant, it might be noise from the cabin resonance. Fixing a bearing is relatively simple; once diagnosed, replacing the bearing should solve the problem.
Does your F150 have any rattling noise? Mine might be due to driving on dirt roads a lot, there's a bit of noise, like the sound of leather rubbing.
I'm looking to install a roof rack on my 2009 manual Touran 2.0, which doesn't have one. Does anyone with the same model have experience to share? 😊
Has anyone encountered a humming noise coming from the left rear wheel of their Defender 110 after parking? The sound stops after about 3 minutes, and there's no noise from the other wheels.
I'm a 2019 JAC Shuailing T8 owner. When starting in 1st, 2nd, or 3rd gear, there's a loud noise from outside the car, like a humming sound. It feels like it might be coming from the transmission. Once the car gets going, the noise disappears. The noise is the loudest in 3rd gear. Is anyone else experiencing this? How did you solve it? Thanks a lot, experts!
Is the engine noise loud on the 2017 automatic model?
Does anyone with a 2008 model experience the same issue? In the hot summer, whether idling or driving, the blower occasionally runs at a high horsepower, making a loud noise. It's more noticeable when idling and parked.
Does the 2017 base model 4WD have an automatic locking feature when leaving the car? Mine doesn't seem to lock.
What are the differences between the Avalon Hybrid 2.5 and the ES300h hybrid? It seems like the exterior dimensions and powertrain are the same. Could someone with more experience explain this in detail? I'm a newbie.
My 2015 manual classic model is shaking a lot when I drive it, and the sound is like it's gasping for air. The power also seems to be lacking. What's going on?
MG ZS
MG ZSOMR 4,999 ~ 8,111Gasoline & Petrol
