avatar-image
محمد رأس
Nov 19
Is anyone experiencing network and antenna issues? I have a 2023 W100, the last batch of 2023 models. After driving it for almost a year, the network is gone. Went to the service center, and they said the antenna module was broken. They replaced it under warranty, but it still doesn't work. Now they say it might be the wiring harness, and I have to get it checked again. It's really frustrating. Has any other owner faced the same issue? How did you resolve it?
I have a 2005 Volvo S40 2.4, and suddenly I can't listen to music. Diagnostics say the music module is broken, and there's no AUX. How can I solve the issue of listening to music?
When the MG ZS 2018 model reaches a speed of 90 km/h, there's a rattling noise from the rear. If the speed is below 90 km/h, the noise disappears. It sounds like an unsecured wiring harness inside the car, making a "da da da" noise. There are no noises when going over bumps or speed humps. I initially thought it was an issue with the right rear (passenger side) taillight assembly, but even after replacing it, the noise persists. I really have no idea where the noise is coming from now. Has anyone else experienced the same issue?
My 2013 model's driver side door lock isn't locking. Is it a problem with the lock itself or the electronic control? Any fellow car enthusiasts facing the same issue? How did you resolve it?
Can the wireless CarPlay of the 2023 model connect via a wired connection, considering issues with wireless delay and sound quality?
I've had my Ousheng for a year now, and after 15,000 kilometers, the engine started making a rattling sound like a tractor! I went to the 4S shop and they updated the software, which fixed it. Will this problem happen again in the future? I know a lot of people have faced this issue. If your car hasn't had this problem, please let us know. And for those who have experienced it, please share how you resolved it. 🙏🙏🙏
Let me share my experience as well. I also have a 2017 MG ZS, one of the first batch from July, manual top configuration. Since then, apart from other issues, the main problem has been the car cutting off power when starting. The entire car loses power, and it won't start. It's fine today, but not tomorrow. The car often won't start. I've replaced several batteries and small parts, but the issue remains. Sigh, I'm disappointed. The car is still at the repair shop now, I'm afraid to drive it. If it stalls, it won't start again, which is frustrating. I used to be a loyal MG fan, but I'm really disappointed now. Next time I change cars, I won't choose MG anymore. Does anyone know what the problem might be?
Zeekr Zeekr 001
Zeekr 001AED 226,900 ~ 271,900Electric
