When you press the brakes, the rear tail lights come on, but the light above the rear window doesn't. Is it a blown fuse?
Will the brake lights illuminate during regenerative braking when you are not pressing the brake pedal?
My car failed to start twice, and various fault codes appeared. The diagnosis showed that the ambient light fuse was blown. Have you guys experienced this? How did you solve it?
Why do you have to press the rear window button once before starting the 2013 GS5?
4Which one is the fuse for the right rear window on the 2018 model?
5The rear tail light on the driver's side doesn't light up when I brake. I just replaced the bulb half a month ago, and now it's not lighting up again. The previous inspection said it wasn't a bulb issue. Has anyone else experienced this? What's the problem?
6Does anyone know how to remove the rear tail light of the MG ZS? Thanks a lot!
7Will the brake lights come on in the strong regenerative braking mode?
8I have a 2016 Haval H2. Have any of you experienced a brake light fault warning when pressing the brake pedal for a long time, but the warning disappears once you restart and press the brake again?
9Why isn't the left side of the lights on my Kia Cerato working when I lock the car? Is it a blown fuse or a burnt-out bulb?
10Is the left front and rear lock lights of the Kia Cerato not working because the bulb is broken, or is it a blown fuse? Does anyone know?
