خالد عزيز
2019-04-24 00:19
Doesn't the exhaust get water in it when it rains?
عبدالله فيصل
عبدالله فيصل2019-04-24 06:14
It definitely depends on how the vehicle is parked. This car has a very low exhaust pipe design, so if water covers the vehicle, it will definitely get in. When parking, make sure to choose a higher ground location.
عبدالرحمن باهر
عبدالرحمن باهر2019-04-24 05:54
After the rain, the roads had quite a bit of water, exceeding the height of the exhaust pipe, so water would definitely get in. However, while driving now, the roads are in good condition and drainage is smooth, so there is basically no pooling of water.
أحمد عَبْدُ الْعَزِيز
أحمد عَبْدُ الْعَزِيز2019-04-24 00:34
As a sports car, even though this car has a relatively low chassis, the exhaust pipe is well-designed. As long as the water on the road doesn't exceed the height of the exhaust pipe, there's no need to worry. If there's a lot of water on the road, it's best not to pass through to avoid water entering the exhaust pipe and causing the car to stall.
