عمر ظافر
عمر ظافر
Dec 4
Who has the original 360 calibration ground parameters? I feel like the dealership didn't adjust it perfectly. The image seems distorted, and I want to adjust it myself according to the parameters.
It seems like your car's brake pedal is hard to press in the morning when starting the engine, but it becomes lighter after the engine is on. This issue didn't exist before, and you're wondering if it's due to a vacuum pump leak. The dealership mentioned it doesn't affect driving. What should you do?
I'm an owner of a 2012 XV and haven't really been to the dealership much. A few days ago, I went to get a small part replaced, and the manager mentioned that there's a recall for this model. It requires replacing the valve springs and brake switch, but it seems too troublesome since it needs the engine to be taken out, so I didn't do it. Has anyone else gone through this? If I don't do it, will there be any impact?
The heated rearview mirror isn't working, but the electric adjustment is fine. I've been to several repair shops, and they all say I need to replace the base, which costs over 2000 for an original one. Any experts here who can give some advice? Thanks!
Can I go to the dealership to ask for a lifetime warranty for the Genesis GV70? I'm worried about the cost of parts in the future, as the original 5-year warranty doesn't seem enough.
Is the hood of the Grand Cherokee lower on the right side? When sitting in the driver's seat and the passenger seat, the hood seems to have different heights. From the passenger seat, the right side of the hood appears to have a greater curve, but from the driver's seat, the left side doesn't seem to have as much curve as the right. The car is parked on level ground, and the seats are adjusted the same, but the issue persists. However, when viewed from outside the car, there seems to be no problem. Is this a visual perception issue?
Hey car enthusiasts, have you noticed this? When you're reversing into a parking spot, the car looks straight, but on the 360 camera, it appears skewed. Before, when I parked using the 360 camera, the image showed the car was straight, but once I got out, the front was actually tilted to the right. And when it seemed straight from the outside, the image showed it was slanted.
Can version 3.1.9 be upgraded? It seems that versions 3.0.3 and 3.1.2 were pulled back just a few days after their release. Version 3.1.10 was just released a couple of days ago and hasn't been pushed out yet. Currently, version 3.1.9 is being pushed in China. In the U.S., 3.1.9 was pushed out in early July, and it has been available in Europe for about a week. According to U.S. car enthusiasts on forums, some vehicles experienced a flickering issue with the 360-degree surround view in versions 3.0.3 and 3.1.2, where the screen would briefly go black and then light up again. After upgrading to 3.1.9, the issue was significantly alleviated during the first week, with flickering still occurring but only going black for 0.2 seconds and then automatically recovering, not affecting usability. However, the results after one week were not satisfactory, with the 360-degree surround view showing more frequent "camera unavailable" warnings than before, still severely affecting use. Yet, some car owners reported never encountering this issue (even with the problematic 3.x versions), so it might be related to a specific batch of parts or the vehicle's personalized settings. Have car owners in China noticed this issue after upgrading, or are there any other problems?
Today, while driving my 2020 automatic Chery Arrizo 5, I heard a squeaky noise from the accelerator pedal when I pressed it to accelerate. When I released the pedal, it didn't return to its original position and kept accelerating, which scared me, so I quickly braked and pulled over to turn off the engine. I then shifted to neutral and started the engine, which roared to over 4000 RPM. After turning it off, I manually adjusted the pedal, heard the squeak again, and then it started working normally. Occasionally, there's still a noise when pressing the accelerator, but the pedal returns to normal. Does anyone know what might be causing this issue or what might be broken?
Why does it feel like the ground clearance of the Sunny is quite high? Looking at the Accord, it seems lower than the Sunny. I wonder if it's just a visual thing or if older cars are generally higher than the newer ones.
Toyota Avalon
Toyota AvalonQAR 119,000 ~ 169,000Gasoline & Petrol
