عبدالله سالم
2024-12-01 14:01
After installing the reverse camera, the car microphone isn't working well! Calls are not being answered!
عبدالرحمن بندر
عبدالرحمن بندر2024-12-02 12:13
Is the microphone cable unplugged?
نايف تركي
نايف تركي2024-12-01 20:33
Installing a reversing camera shouldn't have a direct connection with the car's built-in microphone.
I've upgraded my 2009 Scirocco with the 187b head unit, but the reverse camera doesn't switch the screen when reversing, although the radar works fine. Interestingly, the reverse camera works normally when the car is off, but not when the engine is running. I've already replaced the head unit and the reverse camera, but the issue persists. Any experts out there who can help?
I'm looking for advice from everyone. I want to install a reversing camera on my Mazda 2 and replace the original center console. I'm not sure if the reversing camera center console screens available online are reliable. Do you have any good recommendations?
Who knows where the remote receiver for Xiaoya is? My key isn't working well, and I basically have to get really close to the car for it to respond.
Has anyone experienced the voice control button on the steering wheel not working, and being unable to make calls after connecting the phone via Bluetooth? The repair shop's computer test shows a microphone fault code. How can I fix this? Thanks, experts!
If you want to add a reversing camera to your 207, you can follow these general steps: 1. **Choose a Compatible Camera**: Make sure the reversing camera is compatible with your Peugeot 207 model. 2. **Purchase Necessary Equipment**: You'll need the camera itself, a compatible monitor, and any necessary wiring or connection kits. 3. **Installation**: - **Mount the Camera**: Usually on the rear license plate area or bumper. - **Run the Wiring**: Connect the camera to the monitor and power source. This often involves routing the wires through the car's interior. - **Connect to Power**: Typically, the camera is powered by the reverse light circuit, so it activates when you shift into reverse. 4. **Testing**: Once installed, test to ensure the camera activates correctly and the image displays on the monitor. If you're not comfortable doing this yourself, it's a good idea to have a professional handle the installation to ensure everything works correctly.
Hello everyone! Why isn't the heater working well in my 2020 Rolls-Royce Cullinan BB?
I'm looking to install a central control screen with a reverse camera on my 2014 Peugeot 301. Any recommendations, fellow car enthusiasts?
The reverse camera is seriously lagging, and the dashcam function isn't working. Does anyone else in the car enthusiast group have the same issue?
The reverse camera frequently goes black, and sometimes it works. How can I fix this? Looking for advice from the experts. 🙏
The car is over three years old, and recently the key isn't working well. Could it be that the battery is dead?
Toyota Toyota Corolla Cross
Toyota Corolla CrossAED 89,900 ~ 109,900Hybrid
