Hey experts, is 4 liters of oil enough for a GAC Empow's maintenance? 4.2 liters shouldn't be necessary, right?
How many liters of engine oil are needed for the maintenance of this car?
How many liters of transmission oil does a Smart 4-door need for a change? Do I need to remove the oil pan and replace the filter?
How many liters of engine oil does a Lancer need for maintenance?
4Is it necessary to change 2 liters of oil for a Lancer each time?
5Can the Eclipse Cross only add 4 liters of engine oil?
6Yesterday, I went for a car maintenance, and the oil draining took a bit longer. The mechanic said that adding just over 4 liters of oil wasn't enough, so they added a bit more, totaling 5 liters. Is this reasonable?
7Hey guys, what engine oil is good for the 2019 GAC GA6?
8For the 2013 model of GAC GS5 with a 2.0L naturally aspirated engine, what type of engine oil do you recommend for maintenance?
9Hey folks, got a low oil warning and the next day it started making noise. Even after adding 4 liters of oil, it's still the same. Any idea why?
10Hey guys, for a new car with 15,000 km in two years, what maintenance should be done? Just engine oil, oil filter, and air filter, right?
