محمد فؤاد
محمد فؤاد
Jun 25
Hey guys, can the low-end version be fitted with daytime running lights? I want to ask, is there a switch at the left leg position?
The left electric door of the Sharan doesn't auto lock. The switch works fine, but it doesn't auto lock at the end.
I want to ask about an old Accent bought in 2010, with 140,000 kilometers on it. Can it still run on the highway?
Hi everyone, I need some advice. I bought a second-hand 2017 F150 XLT model, not sure from which country. Here's the issue: No matter what the setting is, when I shift gears, the low beam lights turn on. If I turn off all the lights, the daytime running lights don't come on, but when I shift gears, the low beam lights turn on. When the automatic headlight setting is on, the daytime running lights come on, and in park mode, the low beam lights don't turn on, but after shifting gears, they do. I'm wondering what could be causing this and if there's a solution?
I want to ask, why is the front brake caliper of the Taycan positioned at the front? Isn't it said that for mid-to-high-end cars, the front wheel calipers are generally positioned at the rear? Please explain.
Guys, do the daytime running lights on the Model S really have such a high failure rate? I went to Huaxiang today to check out some used cars, and out of nine I looked at, seven had broken or non-functioning lights. Are they really that unreliable? I even asked the official service, and replacing one costs 1.3W [crying].
Hey car enthusiasts, I want to ask about the 2011 Changan Yuexiang. It's run 120,000 km. Is it worth getting?
I want to ask, how many kilometers can a 2019 HS7 3.0 V6 run on the highway with a full tank of fuel?
I want to ask how many kilometers the 009 actually runs in a test if it claims 700 kilometers. I'm considering purchasing it recently.
I want to ask everyone, what new household cars that run on CNG are available now, and where can I buy them? Thanks.
MG GT
MG GTKWD 4,100 ~ 6,124Gasoline & Petrol
