سعود ق
2024-11-11 17:55
To all 2022 GWM Tank 500 owners, does your car have a delay when starting? Mine has a 2-second delay. Can it be adjusted?
أحمد عَبْدُ الْعَزِيز
أحمد عَبْدُ الْعَزِيز2024-11-12 23:46
It's normal. With a heavier and taller vehicle, like the H9, I used to drive a sedan and no one could cut in front of me. I could stick to the car ahead tightly when starting and moving. But ever since I started driving the Haval H9, I get cut off every time. [I need a moment]
عبدالله بشير
عبدالله بشير2024-11-12 14:02
Why are you rushing so fast? It's not even an electric car. [I want to be alone] [I want to be alone]
نايف أحمد
نايف أحمد2024-11-11 23:04
All turbo engines have lag, unless it's naturally aspirated. But to meet the power requirements, it needs to start at a minimum of 3.0 liters, and the vehicle weight should not exceed 2 tons.
حسين نصر
حسين نصر2024-11-11 18:00
Be gentle when stepping on the pedal, there's no delay. But don't be too aggressive, or there will be.
For those driving the Territory, what's your fuel consumption like? I've calculated mine to be around 10-12 liters per 100 kilometers. A full tank gets me 320 kilometers in the city and 450 on the highway.
How many kilometers can your Mazda 2 automatic run on a full tank? My 2010 Mazda 2 can only go about 480 kilometers, can't even reach 500 kilometers...
Has any 80 owner adjusted or upgraded the high beam distance? Can the service center do it? The illumination is really too short, can't see the road at all at night. [Facepalm][Facepalm][Facepalm]
Dear esteemed car owners: I'm thinking of buying a car recently. Do you recommend the GWM TANK 500? Could you please share some pros and cons? 🌹🌹
I got the black model this year for 68.98, but why are they all from December 2021? I can't find any from the second half of 2022 anywhere.
To all Haval owners, is your infotainment screen working fine?
Bro, what's the reading on your coolant gauge? Mine's showing halfway. I have the second-gen unit.
I have a 2023 JETOUR X90 Zilong. When driving at low speeds, if I press the accelerator, the car suddenly surges forward. However, after reaching 70 km/h, if I release the accelerator and then try to accelerate again, there's about a 2-second delay before the car suddenly surges forward. Is this throttle response delay a common issue?
Is the Polestar 2 still available as a new car, or are they all second-hand now?
Hello CHR owners, what tire pressure do you usually maintain, around 2 point something? For summer and winter, I'd appreciate some guidance from fellow owners! I inflated mine to 2.6 the other day, is that a bit high?
Haval Haval H9
Haval H9AED 109,900 ~ 134,900Gasoline
