لاويل نايف
2025-02-18 16:39
How can I change the front brake pads on a Mitsubishi L200?
طيب محمد
طيب محمد2025-02-21 20:03
Peace! This is an important step in car maintenance, but do you have any idea how to ensure the new pads fit correctly? Because I changed the pads on my car but wasn’t sure about the compatibility.
ثابت عبدالله
ثابت عبدالله2025-02-21 18:01
Hi! Changing brake pads is super important, especially on a Mitsubishi L200. Do you have any extra tips? I tried changing them myself, but I'm having a bit of trouble with removing the wheels. If you have any suggestions, I'd really appreciate it.
جبريل عمر
جبريل عمر2025-02-21 17:53
Hey there! About your question on how to change the front brake pads on a Mitsubishi L200, I totally get where you're coming from. I did this a little while ago and found that having the right tools makes all the difference. Here’s how I did it: 1. Gather your tools:You need a wrench, screwdriver, and a jack. 2. Lift the vehicle:Make sure it's secure. 3. Remove the wheels:Use that wrench to get those off. 4. Take out the old pads:Loosen the bolts carefully. 5. Install the new pads:Make sure they fit snugly. 6. Reassemble everything:Don’t forget to test the brakes before hitting the road! Good luck with it!
ربيع سلمان
ربيع سلمان2025-02-19 10:42
Hey there! Changing the front brake pads on a Mitsubishi L200 is quite straightforward if you follow these steps: 1. **Preparation:** Make sure the car is parked on a flat surface and the engine is off. 2. **Lift the Vehicle:** Use a jack to lift the front of the vehicle securely. 3. **Remove the Wheels:** Unscrew the lug nuts and take off the wheels. 4. **Remove Old Brake Pads:** Unscrew the bolts holding the caliper, carefully remove it, and then take out the old brake pads. 5. **Install New Brake Pads:** Place the new pads into position, ensuring they fit snugly. 6. **Reattach the Caliper:** Put the caliper back in place and tighten the bolts securely. 7. **Reinstall Wheels:** Put the wheels back on and tighten the lug nuts properly. 8. **Test the Brakes:** Before driving, pump the brake pedal a few times to ensure they are functioning correctly. If you need further assistance with car maintenance or modifications, feel free to reach out!
نايف بندر
نايف بندر2025-02-19 10:42
To change the front brake pads on a Mitsubishi L200, follow these steps: 1. Start by lifting the vehicle using a jack, and make sure to use safety stands. 2. Remove the wheels using a lug wrench. 3. Locate the caliper bolts and remove them with a suitable wrench or socket. 4. Gently pull out the old pads and clean the caliper area with a brush. 5. Place the new pads into position and ensure they are secured properly. 6. Reattach the caliper bolts and wheels, then lower the vehicle from the jack. 7. Press the brake pedal several times to ensure everything is working correctly. Always remember to check your brakes regularly to avoid future issues!
Mitsubishi Mitsubishi L200
Mitsubishi L200AED 122,000 ~ 136,554Diesel & Gasoline
