Is the 2023 battery with 52.8 usable? Is there any battery locking? Do you charge it to 100% every time?
How do you charge your phone? The cigarette lighter USB can't charge my iPhone, but it works with OPPO. Does anyone have any solutions?
When the Peugeot 206 automatically locks while driving, but then immediately unlocks, and this cycle repeats every time you start moving, what could be the reason for this behavior?
How to properly use the Polestar 2 battery, which is better between fast charging and slow charging, and do I need to regularly calibrate the battery? 😵
4My E2, with a 47 kWh battery, charges up to 100%, but why does fast charging only add 35 kWh? I've already replaced the power battery due to the same issue, but the problem persists. Please help, it's urgent.
5I always charge when my battery is between 10-20%. I see many people start charging at 30%. Does charging at 30% really help protect the battery better? And do you guys wait until it’s 100% full before unplugging?
6How often do you guys do maintenance? Every 5,000 kilometers?
7Can I use the air conditioning while charging the AION on high-voltage charging? How can I do it without damaging the battery and the small battery? Thanks!
8Has any owner of the 3-motor version of the XP noticed a 4% drop in battery health after six months? I personally feel that I've taken good care of the battery, usually charging between 50% to 80% (slow charging), rarely using fast charging, and charging to 100% no more than five times. When not in use, I keep it plugged in and haven't driven aggressively or used the straight-line speed mode. Despite this, the battery health has still dropped by 4% in six months. Is anyone else experiencing the same thing?
9Do any of you RDX 2.0T owners add fuel cleaner every 10,000 km? The dealership strongly recommends it.
10Dear friends, can the 2023 CS35P's auto-hold function be set to turn on automatically? Or do you have to press it manually each time?
