أحمد تكريتي
2024-10-15 17:58
Can the intelligent driving model's rearview mirror be tilted down during reversing, and can it be enabled through programming?
نايف أنور
نايف أنور2024-10-16 10:05
It seems like only the top trim model has this feature, don't bother [facepalm]
عبد العزيز آدم
عبد العزيز آدم2024-10-16 09:14
The button for adjusting the side mirrors on the right side of the car door is always lit. Have you tried putting it in reverse gear?
نايف أنور
نايف أنور2024-10-16 09:01
It doesn't seem possible. I've also looked into this feature.
Hello, does your car's gear lever wobble? Also, can the side mirror folding feature be enabled in the system after locking the car? When I try to turn it on, it switches back off by itself.
The heated rearview mirror isn't working, but the electric adjustment is fine. I've been to several repair shops, and they all say I need to replace the base, which costs over 2000 for an original one. Any experts here who can give some advice? Thanks!
Isn't there a USB port on the X95 rearview mirror? Can it be used to connect a dashcam?
Can the second piece of glass of the Acura RDX's sunroof open? Also, what's the function of the thing that looks like a camera in front of the interior rearview mirror? Is it possible to replace it with a streaming rearview mirror?
Can you adjust the angle of the rearview mirror on the Geely? It feels like it's tilting too low... Or can it be set to tilt on one side only?
The wind noise from the rearview mirror of the Tianyu is quite loud. It's better when the mirror is folded. How can I fix this issue?
Can the 2015 2.0 Ultimate 508 be set to have the "adaptive rearview mirror during reverse" function? I've tried following the manual a couple of times without success. Does this version not have this feature?
Does the new model's infotainment system look good? Can the old model be upgraded? How is the intelligent driving of this car?
The 2017 flagship model has a reverse rearview camera that doesn't tilt down, even though the setting is checked in the car's system.
Can a car really drive through floodwaters without stalling? Will it need repairs afterward?
Nissan Nissan Pathfinder
Nissan PathfinderAED 158,000 ~ 220,797Gasoline
