أحمد شعيب
2024-11-14 12:55
Do 4S shops usually wash the engine bay during maintenance? Yesterday was my first service, and they didn't even cover the steering wheel or seats. There was water, which looked like oil in the workshop, and it turned out they washed the engine bay while the car was running. Now, when I start the car in the morning, it revs high for a while. After the service, the revs are higher and last longer than before. There's often a rattling noise on the dashboard; when I press it with my hand, it stops. How can I fix this?
أحمد عمرو
أحمد عمرو2024-11-14 20:46
1. Every maintenance session should include covering the steering wheel, seat covers, and paper foot mats. If these are not provided, it's not up to standard, and a complaint can be made at the shop or through the maintenance service evaluation on the Beijing Hyundai app. 2. During each maintenance, the engine compartment should be cleaned. First, turn off the engine, then wash it with misty water. Afterwards, use an air gun to dry it before wiping. There is minimal water on the ground. 3. If the RPM is slightly higher right after maintenance, it might be due to a change in oil viscosity after replacing the engine oil. 4. For dashboard vibrations, you need to locate the vibration points and address them accordingly.
My MG GT experiences jerky acceleration, and there's a squeaking sound when I turn the steering while driving. Additionally, there's a squeaking noise when I rev the engine after parking. What could be the issue?
There's a rattling noise like a loose plastic shell when accelerating while driving, but it's not there when revving in neutral. The noise also disappears when you press the accelerator pedal down hard after accelerating.
Hey guys, my car got hit by AC water droplets, can't scrape it off or wash it away. What can I use to remove it?
Yesterday, I went for a car maintenance, and the oil draining took a bit longer. The mechanic said that adding just over 4 liters of oil wasn't enough, so they added a bit more, totaling 5 liters. Is this reasonable?
How can I adjust the headlights to aim higher? The low beams are too low on my 2018 1.8T model.
Is it normal for my manual comfort version car to have the engine rev up to 3000 RPM and make a lot of noise when driving over 100 km/h on the highway?
Today, while washing my car, I noticed that all the left side windows have markings, but the three right rear windows don't. What's going on here? Did I accidentally buy a damaged car? I own a 2021 Subaru Outback flagship model.
Hello everyone, when I start the car and reverse while turning the steering wheel, does anyone hear a noise from the lower control arm? It goes away after a while! My car has done 110,000 kilometers. The engine also makes a rattling noise when starting, and the RPM is over 1000, but it settles down in a few seconds! I suspected the chain, but since the RPM is also high, I ruled that out! Has anyone experienced something similar?
My 2013 manual 2.0 Peugeot 3008 stalled twice while idling with the AC on for forty minutes yesterday. Can anyone explain what the issue might be? I drove another 320 kilometers on the highway afterward, but I'm still worried.
I've driven my 2024 Wrangler for 10,000 kilometers. The first service was done at the 4S shop at 5,000 kilometers. They suggested I service it again at 10,000 kilometers. Do I need to change the engine oil this time?
Hyundai Hyundai Tucson
Hyundai TucsonAED 86,940 ~ 254,900Gasoline
