سعود جعفري
Nov 7
In the Changan Uni-T, the central control screen doesn't turn off, and when the engine is started, the RPM shows zero. After shutting down the engine and then remotely starting it with a phone, everything returns to normal. Could any fellow car enthusiasts explain what might be causing this issue?
Experts, my Mitsubishi Galant's remote lock doesn't flash the lights, but it can still lock. The repair shop checked the hood and trunk, and everything's fine. They said my central control module is broken, but they can't find the module in the car. Any guidance from the experts would be appreciated...
I have a 2006 Accent, and the current issue is that it won't start. The engine cranks normally when trying to start, and there are no warning lights. However, it can be started by pushing. I've checked the wiring, fuel line, and starter, and everything seems fine. The mechanic here replaced the spark plugs and fuel pump assembly, but it still won't start! Can any expert advise me on this? 🙏
It seems like your 2011 Phaeton is experiencing some issues with the remote unlocking and the keyless start system. Sometimes you have to use the mechanical key to lock and unlock the car, and the keyless start doesn't work. Occasionally, after using the mechanical key to start and then turning off the engine, the remote unlocking and keyless start work fine again. What could be the problem?
4When I stop my KIA Soluto, turn off the engine, and shut everything down, after about a minute, there's a strange noise. It sounds like a locking noise, but it's not exactly that. Does anyone else experience this with their automatic transmission? Does anyone know the reason? Please let me know.
5You can start by calmly explaining the situation to the 4S shop. Let them know that after your recent maintenance, the coolant return hose wasn't secured properly, leading to damage to the turbocharger and causing the car not to start. Ask them to take responsibility for the mistake and discuss possible solutions, such as repair or compensation. It's important to have any relevant documentation, like your service records, ready to support your case.
6It could be that the battery is weak, especially if it's been sitting overnight. Cold temperatures can also affect the battery's performance, making it harder to start the engine. You might want to check the battery charge and connections to see if everything is in good condition.
7Does the 2011 Nissan Sunny manual model have an engine immobilizer with a security code? It seems like a mechanical key alone can start it. Does it not have a central engine immobilizer system?
8Has anyone experienced the car shutting off automatically while driving, and then it won't start? You can't shift gears, the car rolls by itself, and the engine warning light turns on automatically.
9Does this car have remote start via mobile phone?
10How can I set up remote control for the Changan CS35PLUS with my phone? If any expert knows, please let me know.
