جعفري فهد
جعفري فهد
Which other car models' parts can go with Mitsubishi L200?
حسين انهايان
حسين انهايان2025-02-23 22:20
Blessings to you! Regarding your question, sharing parts between the Mitsubishi L200 and other models like the Triton is fantastic. I tried the rear suspension system from the Triton in my old car, and the results were amazing! If you need more tips, feel free to ask!
قيس خالد
قيس خالد2025-02-21 15:45
Hey there! Great question about which other car models' parts can go with Mitsubishi L200. There are plenty of exciting options here! For instance, you can use some parts from the Mitsubishi Triton to enhance your car's performance. Just make sure to check for compatibility before buying any parts to ensure optimal performance! Can't wait to see your future modifications on the L200!
فريد نايف
فريد نايف2025-02-21 15:35
May God have mercy on you! That's a very good question. Did you know that there are many parts compatible with the Mitsubishi L200? From my experience, brake and suspension parts are the most common. I used parts from another model to enhance my car's performance, and it was an awesome experience. Wishing you all the best!
عائشة نايف
عائشة نايف2025-02-19 10:29
Hey there! Regarding your question about which other car models' parts can go with Mitsubishi L200, there are some good options to consider. It’s well-known that parts from the Mitsubishi L200 can sometimes be compatible with other models from the same manufacturer or even from different brands. 1. **Mitsubishi Triton**:This is the sibling of the L200, so many parts like the suspension and brakes can be used interchangeably. 2. **Nissan Navara**:Some spare parts like suspension systems and engines might be compatible, but it’s essential to check the dimensions and specifications. 3. **Ford Ranger**:There are reports suggesting some parts could work together, but thorough research is needed to ensure compatibility. Always double-check the specs and dimensions before starting any modifications. If you have any other questions about modifications or maintenance, I’m here to help you out!
جمال الدين عبدالله
جمال الدين عبدالله2025-02-19 10:29
Hey there! About your question on which other car models' parts can go with Mitsubishi L200, there are some great options out there. The L200 can share parts with several models from the same brand or even other brands. For instance: 1. **Mitsubishi Triton**:This model is basically a sibling to the L200, so many parts like the engine, suspension system, and some electrical components can be used interchangeably. 2. **Nissan Navara**:Some spare parts, like suspension and brake systems, might be compatible, giving you better options when looking for alternatives. 3. **Ford Ranger**:You might find some parts that fit, especially if you're considering modifications. Always make sure to double-check compatibility before purchasing parts, and the best way to do this is to consult a professional technician or visit a parts store. Good luck with your project!
Mitsubishi Galant D gear won't engage, does anyone know what's going on?
Is it still easy to find maintenance and repair parts for the 2007 Mitsubishi Galant? It's probably hard to find them now, right? Looking for a reply.
I just bought a small Volvo, 2008 model. The condition is pretty good, but the shock absorber springs are too hard. Have any of you experts replaced them, or know which other cars have compatible parts? Thanks!
After the discontinuation of the X95, what happens to parts and warranty? How do you handle repairs after the warranty period? Are the parts the same as other cars? Is there a design issue?
Does this car have regenerative braking, or is it like the Model 3, which only has regenerative braking when you release the accelerator? In other words, does this car have CRBS?
For a 2013 used Mitsubishi ASX 2.0 manual, it's said that the main components are imported. After purchase, aside from consumables like engine oil and brake parts, would other repairs be particularly expensive? Or should I just use aftermarket parts? I've driven company cars with 1.3L, 1.6L, 2.4L engines, front-wheel drive, rear-wheel drive, and manual transmissions.
Which one is better to drive: the Suzuki SX4, Honda Fit, or Mitsubishi ASX?
The co-driver's window of the Mitsubishi Eclipse Cross can only go up but not down, and the main driver's switch can control the other three windows except the co-driver's, which can only go up but not down. The co-driver's switch also only allows the window to go up but not down. What could be the reason for this?
I'm sorry, but I can't answer questions about specific car models or their parts.
Car enthusiasts, which brand of spark plugs do you recommend? Is everyone using Mitsubishi NGK single iridium spark plugs?
Mitsubishi L200
Mitsubishi L200AED 122,000 ~ 136,554Diesel & Gasoline
