avatar-image
نايف سلطان
Oct 23
My 2013 Mazda 6 had an issue where the car lights didn't turn on after unlocking, and when I put the gearshift in Park, the gear indicator light also didn't illuminate, almost couldn't start the engine. Then, at night, after locking the car, it beeped three or four times by itself. What's the problem? Can anyone help?
عبد المجيد فهد
عبد المجيد فهد2024-10-24 11:34
Check if the battery charge level is normal.
عمر جلال الدين
عمر جلال الدين2024-10-23 23:34
Hood microswitch
Guys, I've got a problem! Sometimes when I go through the underground parking lot, I hear a "beep beep beep" sound. I check it out and find it's my car making the noise, and the yellow light flashes rapidly. The sound stops after about 10 seconds, but the yellow light keeps flashing for several minutes. It's happened more than once! Can anyone tell me what's going on? Can I turn it off? It's pretty annoying for others too.
The car wouldn't start just now, and the screen didn't light up. I couldn't unlock it with the key fob either, so I had to manually turn the car door open with the key.
When I put it in drive, the engine stalls. I have a 2017 model 95 with over 70,000 kilometers now. Recently, I've encountered a problem where the engine stalls when I put it in drive while waiting at a red light. It's happened a few times already, but the 4S shop couldn't find the issue. Has any fellow car owner experienced this problem?
I've heard that the 2019 V40 has 7-color ambient lighting. But I couldn't find any pictures online. Can someone please take a picture of the night effect? I'd really appreciate it.
What's going on? The car locks itself five seconds after unlocking.
I have a question for everyone. Occasionally, when opening the door of my 2021 Subaru Outback, the hazard lights flash a few times accompanied by a beeping sound, then it disappears. There's no indicator light on the dashboard, and there's no issue while driving. What could be the reason for this? I've been driving it for a few years and it's the first time I've encountered this situation.
When starting the engine, the malfunction indicator light flashes briefly and then goes off after starting. What could be the issue?
My car has keyless entry, but after unlocking, the car gives four alarm sounds. What's going on? This didn't happen before. It used to just unlock automatically when I got close, with the lights flashing but no sound. Now it flashes four times and gives four alarm sounds!
Mazda Mazda 6
Mazda 6AED 82,203 ~ 129,499Gasoline
