ميرزا حسين
ميرزا حسين
Nov 16
Hi everyone, I'm wondering if any of you have experienced loud engine noise when the engine kicks in on the 2024 Hybrid Highlander. I did some research online and found that the 2022 Hybrid model had issues with the engine mount, and replacing it with the same V1 engine mount from the Sienna could solve the problem. Does anyone know if the 2024 model has the same issue?
Comments( 10 )
حسن نادر
حسن نادر2024-11-23 22:28
I just picked up the 2024 Elite Edition today. I've been driving the 2022 Highlander Hybrid for 2 years. The engine noise reduction in the 2024 model is noticeable, and the four doors feel heavier. The sound insulation has also improved a lot. [Thumbs up][Thumbs up][Thumbs up]
فهد شمس
فهد شمس2024-11-23 19:05
The sound insulation is indeed a bit lacking. Sometimes, when the loudspeaker volume is high, it even causes vibrations.
ضياء عبد العزيز
ضياء عبد العزيز2024-11-23 06:20
You'll get used to it. 😄
أنيس عبدالرحمن
أنيس عبدالرحمن2024-11-23 03:24
The noise issue is mainly due to maintenance problems. In a market where 80% of the engine oils are fake, it's impossible for noise to be minimal. The real reason is poor lubrication leading to increased wear. After over 100,000 kilometers, you'll understand why a new car that's not well-maintained not only gets noisier and consumes more fuel, but also has a higher failure rate and a shorter engine lifespan over time!
2
ق فهد
ق فهد2024-11-23 00:08
The same size. I test-drove the 2023 model and bought the 2024 model. There's no difference.
هشام علي
هشام علي2024-11-22 21:42
They used to say the soundproofing wasn't good! I didn't believe it before, but now I do.
20
هشام علي
هشام علي2024-11-22 21:40
It's just so loud! Damn it! I thought mine was the only one that loud! Turns out it's the same for you guys too.
نايف داود
نايف داود2024-11-17 14:26
The 2024 model has been changed.
سلمان يعقوبي
سلمان يعقوبي2024-11-16 09:08
حسن صابر
حسن صابر2024-11-16 09:06
Naturally aspirated cars are all the same; if you like quietness, go for an electric car.
