أحمد بلال
Nov 19
Hey everyone, how many kilometers do you wait between your first and second car maintenance? The manual says 10,000, but the dealership insists it's 5,000. When I showed them the manual, they said 7,500 is also fine. There's no clear answer.
Model X, 40,000 km. There's a consistent humming noise from the rear wheels while driving, most noticeable at speeds of 35-40 km/h. You can feel a slight vibration in the floor when sitting in the back seat. I've been to the dealership a couple of times for this, and the last time, the technician confirmed the noise. After checking, they said the half axles are fine and concluded it's due to tire aging. I've heard that 21-inch tires tend to wear unevenly and might need replacement around 40,000 km. The tires only have 40,000 km on them, and the tread still looks clear. Is this really possible?
Is it normal for the accelerator pedal to make noise? I've had this issue since I first got the car, and it's really annoying. The dealership says it's normal. Fellow car enthusiasts, is this really normal?
4Is it a problem with the gearbox if sometimes the 4th gear won't shift down to the 3rd gear in a 2015 Honda City with a manual transmission? Waiting online for someone knowledgeable about cars to answer.
5My car was registered in 2018 and has just over 10,000 kilometers. It's been in the repair shop for half a month now. They said it's the electronic rocker arm that's broken. First, they tried replacing the spark plugs, but that didn't work. The ignition coil didn't work, and neither did the injectors. Then they said it's the electronic rocker arm. Wow, it costs 12,000. Sigh, they suggested I replace the engine, which is around 15,000. I don't even know what to do. This car isn't worth 50,000 now, and fixing it costs over 10,000.
6I've got a T-Roc 1.5T for about a year now, and did the first service at 4,000 km. The dealership said the second service is due either after a year or at 10,000 km. Now it's at 11,000 km, and I'm feeling that the low-speed acceleration isn't smooth. Should I just go and change the oil outside? The dealership mentioned that 10,000 km is too long.
7Yesterday, I went to the dealership to check the air conditioning pressure. It was at 16 psi and the temperature was 7.6 degrees, and they said everything was fine. But by noon, it wasn't cooling anymore. 🤦♂️
8I've driven my 2024 Wrangler for 10,000 kilometers. The first service was done at the 4S shop at 5,000 kilometers. They suggested I service it again at 10,000 kilometers. Do I need to change the engine oil this time?
9What should I do if the touchscreen stops working? The dealership said it's a common issue, and since it's out of warranty, they suggested I replace it myself (which is quite honest of them). Has anyone else encountered this problem? Which type of screen is suitable to replace it with? 😊
10How often should transmission fluid be changed? I bought my Outlander in July 2020, and it has been four years with only 10,000 kilometers driven. However, the dealership says it's time to change it due to the time elapsed, or else the warranty won't cover transmission issues. Has anyone here changed their transmission fluid? Did you use the mechanical circulation method or the gravity method? With just 10,000 kilometers, do I need to remove the oil pan for cleaning before changing?
