سلمان فادي
سلمان فادي
Oct 20
I bought my X70 in March 2020. Recently, during maintenance, I noticed that the car's chassis was rusted terribly. When I asked after-sales service, they simply said the warranty had expired and shifted all responsibility away. Is it because the materials are of poor quality? Fellow car owners, have you encountered this situation? Is there any good way to remedy this?
When starting a cold car, it should normally take about 2 seconds, but sometimes it takes 5 or 6 seconds. Does anyone else have the same issue? Last time, I replaced a solenoid valve under warranty, but it didn't help. The warranty is about to expire, and I want to fix the problem. I have a 2019 GAC GA6 Luxury Edition.
Hi everyone, the electronic steering lock of my Chery Jetour X70 is broken and needs to be replaced. The 4S shop said it's no longer under warranty, so I have to replace it myself. It seems to cost several thousand. Does anyone know if the 10-year or 200,000 km warranty indicated by the lifetime warranty badge on Jetour still covers it? The steering system is an important part of the car. The car was registered in August 2020, so it's been almost four years. Does anyone know if this is still under warranty? Please help.
I have a 2017 Haima S5 manual 1.5T, and I'm facing some issues: the car door is rusted through, there's a noise from the chassis (note: I've replaced the lower control arm, ball joint, steering gear, and engine mount but still can't find the problem), and the USB port inside the car has poor connection. Is there anyone experiencing the same issues? Any solutions?
Has anyone encountered cracked door handles on a 20-year-old Cayenne? The 4S shop refuses to repair them under warranty because it's expired. What should I do?
My car is just over 3 years old and has only 36,000 kilometers on it. The electric tailgate is acting up right after the warranty expired for a month. So frustrating! I asked about it, and they said it would cost over 2,000 to replace. Plus, at the 4S shop, they just told me it's out of warranty...
After 8 years with my old petrol car, it started burning oil, and I noticed a lot of people around me were switching to electric vehicles. That got me thinking. I was originally planning to get the top-spec Tank 300 (Menglong), and during the National Day holiday I went for a test drive — it met my expectations.On the way back, I stopped by a Jetour dealership and saw the T2. My daughter instantly fell in love with the exterior and interior — it completely overshadowed the Menglong in her eyes. Looks clearly played a big role, and after a test drive, it felt good enough. Since I don’t really need 4WD for daily driving, I booked it right away. Looking back now, I do wish I had waited for the 4WD version — a bit more power would’ve been nice.For this type of vehicle, electric power saves a lot. For daily use, my cost is just around 0.10 AED/km (charging at home on off-peak rates of 3.3 AED/kWh). My daily round-trip to work is under 20 km, so I only charge every four days, when the battery hits around 20%.For long-distance trips, I don’t bother with charging — it’s too much hassle. I just set the car to preserve 60% battery and drive on petrol. Even if fuel consumption is slightly higher, it’s fine since I only do a few road trips per year.The car is heavy and feels solid on the road. Acceleration is decent, but the 4WD version definitely would’ve offered better power and confidence. I’ve had the car for over half a year now. So far, the only issue has been a slight noise from the steering system — which was fixed. Other than that, no major problems. Buying a car always involves a bit of luck anyway.The biggest downside is the driver assistance system — it lags behind the competition. The infotainment system has improved a bit with the latest 4.11 update, but it still has room for improvement.Overall, I’m quite satisfied. Compared to many newer EV startups, Chery is an established brand. The lifetime warranty adds a lot of peace of mind, especially on the powertrain and electric components.
I had the chance to try out the new Toyota Corolla, the 1.2T Elite version. Honestly, there aren’t many changes in the design compared to the previous generation, but I thought I’d share my thoughts anyway. The engine performance isn’t particularly strong — 116 horsepower on a car this size is just acceptable. But when you push it and let the RPMs climb, it actually feels better than expected. It’s not slow, and it feels lighter than I thought it would. The CVT gearbox is smooth and decent overall, although at low speeds there are some light vibrations and a bit of drag when you lift off the throttle. When you demand sudden acceleration, it takes a little time to reach the higher revs, but it’s not annoying. The suspension handles big bumps well, but you can feel smaller imperfections in the road, especially at lower speeds. On curves and sharp turns, the car holds itself pretty well and stays composed — that was a nice surprise. The steering is great. It’s light at low speeds and firms up nicely as you go faster. The response is smooth and precise, and the brakes are easy to get used to and feel very natural — no issues there. Noise insulation is average. Wind noise is handled well, and the engine isn’t too loud, even at high RPMs — that’s actually better than the hybrid version. But road noise does come through at higher speeds, and ambient noise isolation is just okay. Inside, the design hasn’t changed much — it still feels quite basic. The materials aren’t great; most of the interior is hard plastic. The screen and instrument panel haven’t been upgraded like in the 1.5 or hybrid versions. The infotainment system is slow and outdated — not what you'd expect in a 2024 model. Front seating is fine — you can adjust the driver’s seat to a comfortable low position and the steering wheel aligns well with it. The back seats, however, aren’t great. The space is average, the seatback is a bit upright, and the cushion isn’t very long. The trunk, on the other hand, is decent and handles luggage well. In terms of safety features, you do get useful tools like radar and driving assist, but there’s no rear parking sensor — which is strange. Overall, the car isn’t lacking in features, but the priorities feel a bit off. In the end, this car doesn’t really surprise you — and that might actually be a good thing for people who prefer something reliable and familiar. It’s not futuristic, but if you’re after dependability and ease of use, it could still be a smart choice — especially with how crowded the market is becoming with hybrids and EVs. Ultimately, it depends on your needs and your budget at the time of buying.
I bought the new Toyota Corolla 1.2T. The engine has 116 horsepower—not super powerful, but its performance is better than I expected, especially when you push it. The CVT gearbox is smooth, though there are occasional slight jerks. In terms of comfort, it’s pretty good. The suspension absorbs big bumps well, but you do feel the smaller ones a bit. The driving is stable, the steering is light and responsive, and the brakes are solid. Wind noise is well-insulated, but tire noise becomes very noticeable at high speeds. The interior feels a bit outdated, with lots of plastic materials. The screen is weak, runs the old system, and is barely backlit. Front space is fine, but the back is a bit cramped. The trunk has a decent amount of space. It comes with a full set of safety features, but no parking sensors! The bottom line? It’s a practical, reliable car—great for people who aren’t looking for fancy tech but want something dependable and easy to drive.
Look, I'm one of those people who did a lot of research before buying a car. I tried everything from the Geely StarRay to the Nissan Sentra and the Volkswagen Jetta. But in the end, I went back to the classics and chose the 2021 Toyota Corolla 1.2T Plus—because, quite simply, it doesn't come with problems, and that's the most important thing for someone in their 30s with a job, a home, and responsibilities. I bought it with a few extras thrown in, like LED headlights, parking sensors, window tinting, floor mats, and 7 free maintenance services. The car won't blow your mind or steal your heart, but it’ll stick with you and do its job. It's comfortable, smooth, has solid suspension, and its performance is more than enough for daily drives—you don’t need to fly. The interior is simple but comfy. The console doesn’t have CarPlay, but it's not the end of the world—I just connect it via Wi-Fi and that’s it. Fuel consumption is around 6.3L per 100 km, and I drive calmly. In short, the Corolla isn’t the best car in everything, but it's probably the one with the least headaches—and that matters more than fancy specs or a big screen.
I bought a used Nissan Sunny in 2018—it was a 2015 model, and I was the second owner. I paid 160,000 EGP for it. When I got it, the odometer showed 60,000 km, but it was obvious they had tampered with it—just by looking at the tires and other details. Still, at the time I just needed a car to get me around. The first year with the car was honestly a pleasant surprise. Fuel consumption was excellent—even with a bit of aggressive driving, it was doing about 6L/100km. That was after I cleaned the injectors, changed the spark plugs, and washed the sensors. After that, the throttle response was smoother and performance improved. One time, I managed 700 km on a single tank—but that was rare. Usually, it did just over 600. Interestingly, it consumed more fuel on the highway than in the city, which is a bit odd but shows it's built more for short urban trips. Driving it was light and smooth. The steering was soft but had a decent return, the suspension was soft but not too floaty, and even though the car is lightweight, it felt more planted than I expected. Honestly, it’s one of the most comfortable cars I’ve ever driven. The interior space is amazing. From the outside, it looks small, but inside it feels like a full-size sedan. Nissan clearly prioritized passenger space—they shrunk the hood and dashboard, which is great, but comes at a cost. The insulation is terrible—you hear road and wind noise like you're riding a tuk-tuk. And the bodywork is so thin, it feels like you could crush it with your hands. Put your foot in the wrong spot, and it feels like you'll puncture the floor. There were also a few issues: the stereo was poor, I had to replace the A/C motor, and I still get some strange noises. But in the end, I see the Nissan Sunny as a very basic car that offers comfort, space, and ease of use—but at the expense of build quality, sound insulation, and overall sturdiness. If you're on a tight budget and just need something to get you through your daily drives without asking much, it’s a logical choice. But if you’re looking for luxury or durability... look elsewhere.
Jetour X70
Jetour X70OMR 7,269 ~ 8,249Gasoline & Petrol
